how to get rid of serious wiper scratches on your window
my rear windscreen has got some serious wiper blade scratches on it what's the best way to get rid of this ?
many thanks
Karl
  • Replies 12
  • Views 2.5k
many thanks
Karl
Get a new Window :-)
how much would that cost though :/
Wouldn't like to say really........someone will comment and give you some more info I'm sure :)
Apparently **DO NOT QUOTE ME ON THIS!!** you may be able to sand the scratches out - Don't know if that would work or how, but its a suggestion non-the-less!
^ ^ ^ would need to be a very fine grit...
I`ve just bought 100g of cerium oxide glass polish and some felt polishing heads all off ebay to try and remove the wiper scratches I have on my rear windscreen. I`ll have to let you know how I get on. Cost about £10 delivered. There`s a thread on detailing world by a guy called Shredder who has done it with some really good results. About £60 for a new front screen thru ure insurance, you`ll need a baseball bat as well
:lol: loving the baseball bat comment, got a link to the stuff you bought of ebay ?
cheers
Brasso works reasonably well.
try t-cut, or other cutting compounds.
failing that, buy grit 5000-20000 sandpaper off ebay and try that.
autoglym do a glass polish!
if all else fails you could just get a whole replacement boot lid,plenty on ebay so your bound to find one in your colour,4 bolts hold it on and its got to be easier to swap the boot lid than sanding the glass!?!?
I guess it would be OK to use the glass polishing kits you can get from Frost auto as it's the rear screen. But, and this came from a man in the trade, when you try to polish out scratches on the front screen you WILL affect the veiwing properties. you will be introducing a slight concave shape to the glass and that will make it act as a lense in that area, so your vision through it will be distorted to some extent. He said in some cases it was so bad that it failed an MOT which it didn't do before where the scrape mark was....
He had no vested interest in telling me this, just pointing out that in order to remove a scratch you have to remove the top layer that is scratched.
Just for info.
