NO Longer for sale
After much thought and deliberation, I miss old skool cars. I love this GTi to pieces, but it's just not what I'm currently looking for. I'm an old skool kinda guy...
About the car:
*2001 Polo GTi in Reflex Silver
*Average miles at 114,500 miles (used as daily so will go up)
*MOT: 28th April 2010
*Tax: December or January, I will double check later on..
*2 Genuine original keys
Standard GTi Spec:
*1.6 16v - 125BHP
*Xenons with bumper washers
*GTi Specific Splitter
*GTi roof Spoiler
*Climate Control
*Electric windows
*Electric and heated mirrors
*ABS
*EPC
*EDL
*twin airbags
*power steering
*black with red pin stripe seat belts
*Red stitched, leather steering wheel
*Honeycomb grill
*Foglights
*Cup Holders
*Sports Seats
Optional Extras:
*Front Genuine VW, GTi specific Car Mats (black with red piping) - back were ordered and paid for but then it transpired that they are on obsolete from VW as of 28th August 2010!! - Gutted
*Genuine VW Headlight Protectors
*Genuine VW black front VW badge with body coloured backing (have the rear too, just prefer the chrome on the back)
Service History:
*Full Service History - All documented and present.
*Only 2 of the most recent MOT's certificated (Due to VW performing the rest from 2001 to 2008 all documented) - But all mileage is documented at least yearly through VW receipts and history from 2001 to 2009.
*VW/Skoda service history up until 2008 (A VW garage turned into a Skoda garage and it kept getting serviced there after the change)
*Serviced by an independent VW garage specialist with genuine parts in 2008/9.
*Serviced myself therefore after with receipts and photo's to prove, using genuine VW parts or better.
Other Information:
*The car is run on V-Power only and can easily achieve 40mpg if driven carefully, expect mid-low 30's on normal runs with a bit of a heavy foot..
*Pulls very very well, VVT kicks in as it should and sounds schweeeeeet!
*Vagcom fault code free with a recent printout to prove.
*I have owned the car since April and bought it with the intention of keeping her for a long long time and have spent £1000+ on parts alone getting her up to scratch and running nice, I am pretty anal with looking after cars and spend money on the right area's - making them run well!
*The car hasn't let me down down once since ownership (done 5,000 miles-ish), all the above money was spent through personal preferences of a nice running car rather than the car letting me down and me having to fork out. Prevention rather than repair!
*Please don't be put off by the mileage, the car is very tight and drives faultlessly. I even get comments of fellow GTi owners on how nice it drives compared to theirs.
*No gearbox issues whatsoever, no crunches, leaks, whines, bangs, selects gears as it should etc etc..
*Comes with the original service book, information booklet etc, in the original wallet
*I have an original genuine brochure from 2001 showing the Polo specs and information, including the GTi.
Engine and gearbox - including any recent work:
*Standard GTi Engine bar BMC CDA Carbon Fibre enclosed air filter and relevant air ducting (May 2010)
*Genuine VW Gearbox seals and Genuine VW Gearbox oil (2008)
*Sachs uprated Clutch kit which included the release bearing (May 2010)
*Genuine VW Clutch Cable (August 2010)
*Oil Change - Castrol Magnetec 10w40 - it's had Magnetec 10w40 it's entire life from VW - Documented (Aug 2010)
*Oil filter, fuel filter, pollen filter, spark plugs, coolent - All Genuine VW (August 2010)
*Genuine VW GTi HT leads - Red type (September 2010)
*Replacemnt used Coil from a 60k car - Vagcom tested as working (August 2010)
*Genuine VW Gearbox Oil (September 2010)
*ECS Magnetic sump plug (September 2010)
*Genuine VW Cambelt Kit, including both belts and 3 tensioners (September 2010)
*Genuine VW Waterpump and new G12 coolent (September 2010)
*New Sealant on the rocker cover (Sept 2010)
*I also have the original airbox and engine cover which will be included in the sale
Suspension & Running Gear:
*Genuine VW ABS Pump (2009)
*Genuine VW front brake discs, pads and fluid, with loads of life left (2008)
*Genuine VW rear disks and pads with loads of life left (2006)
*Brakes work as they should - Nice and firm pedal and stops on a penny
*TA Teknics shocks and springs with new top mounts - 60mm (2008)
*Throttle cable/pedal re-aligned and parts (Genuine VW) replaced to fix the common low pedal problem (August 2010)
*Pedal Box Recall performed in 2006... No proof of this as I was told by Leeds VW (Elland Road) over the phone.. Any one can call up with the Reg to any VW to confirm this.
Tyres & Wheels:
*15x7 Lenso BSX (2007/8)
*195/45/15 tyres, Toyo Proxies up front, Firestone rear. The front have worn on the inner edge due to negative camber which has now been corrected, the rest of the front tyres are good with lots of tread - Still MOT passable. Rears have loads of tread left.
*Carbon fibre style BBS center caps.
Bodywise/Exterior:
*Osram Cool Blue Xenon D2S Bulbs 5000k - upgrade from the standard Osram 4300k as supplied by VW (June 2010)
*White LED Sidelights and Osram Night Breaker Main full beams (June 2010)
*White LED foglights and number plate bulbs (September 2010)
*Silvertec front indicator bulbs (2010)
*Brand new in bag, Genuine VW front splitter (not yet fitted, I can fit or supply to the new buyer)
*MK4 golf GTI anniversary red style badges, front and back, I have one spare in case one get's stolen. (May 2010)
*De-wipered rear (still have the wiper to re-fit if you wish)
*The car cleans up exceptionally well and shines beautifully.
*I paid £300 in April 2010 getting all dints removed so the car is 100% dint free
*Front Aero Wipers fitted
*UK Font pressed metal plates, front and back - Legal (are stamped for the correct reflectiveness and have the company name and postcode as required by law).
*Dubmeister plate surrounds, front and back
*I also have the original number plates and VW plate surrounds to be included in the sale
Interior:
*Genuine VW boot mech/microswitch (September 2010)
*standard GTi Interior
*Boot light works as it should
*All Lights work on the dash so no hidden surprises!
*All Electrics work (widows, mirrors climate etc)
*All interior bulbs work (For buttons etc)
*Standard Gamma head-unit
Bad points
Bodywork
*It has a few marks here and there, mainly on the passenger front/rear arch were a previous owner scraped against something, it's been touched up and isn't too bad, about 10x1cm.
*Passenger door has a a 50p sized mark, what looks like someone has scrubbed it with a scourer!!?? It's not gone through the paint and I'm confident a machine polish can fix this.
*Front bonnet has some slight corrosion on the very front/underside, about 0.5x1cm, from what looks like it's rubbed on the underside from closing the bonnet.
*It has the odd stone chip here and there, mainly front/rear bumper.
Interior
*One small cigarette burn in the driver seat - This is not from me as I don't smoke. The burn is in the corner and is hard to see unless you look for it.
*Interior grab handles have marks on, like all 6n2's!
*Doesn't come with the CD changer as it wasn't in the car when I bought it
Running gear
*The front brakes make a grinding noise and squeek on soft braking. I'm confident stripping and copper greasing the relevant parts will fix this as there is years of life in them still.
*The brakes also need a lick of red paint as the old has fadded/come off.
*Note: Reading the brakes section back, it looks like the brakes are bad, they are not.. They work as they should, nice and firm with good stopping power.
Engine
*The exhaust rattles slightly when stationary and on a hill facing down.. Never bothered me enough to sort this.
*The rocker cover was faded with flaking paint. I have re-painted this red, but it's not the smoothest of jobs
*PLEASE NOTE: I have made the car sound much worse than it actually is, I just HATE going to view cars described as mint/immaculate and turning out they have marks and issues obviously hidden from me by the seller. All in all the car is in exceptional condition, inside, outside and mechanically for the age. I just like being honest, stops time wasting.. This way you know the crack, I know the crack and there are no nasty surprises when you arrive for a viewing.
Pictures: - Will get more in the next few days..
Pictures of Damage
Price:
£2,795 ovno
No stupid offers please, if the car doesn't sell close to this price it doesn't sell (I'm already on a MASSIVE loss selling at this price)
I may be interested in a swap.. I have a very specific list of cars I may want:
G40 - any colour but not red or white.
MK2 Golf GTi 16v - Preferably Oak Green, Black or Royal Blue Metallic, preferably 3 door unless the 5 door is something special.
MK2 Golf GTi 8v - Must be amazing condition and well spec'd as I really want a 16v. As above colours. Must be a 3 door.
MK3 Golf GTi 16v - preferably a 20th anniversary 16v in silver or black. Or Windsor blue metallic, black or silver 16v.
Corrado 2.0 16v - not to fussed about the colour of corrados.
Corrado 2.9 VR6 - colour as above.
MK1 Golf GTi Cabriolet - Must be a cabby and a GTi. Must be a late spec with the karman kit, preferably electric windows and roof too.
Audi A4 (B5 chassis) 1.8t Quattro Sport - Any colour, must be good condition.
Audi A4 (B5 Chassis) 2.8 V6 Quattro - Would have to be a nice one over the 1.8T.
Audi Coupe 2.8 Quattro - Any Colour
Audi Coupe 20v Quattro - Any colour
Audo Coupe 2.0 16v - Must be nice
Audi Coupe 2.6 V6 - Must be very very nice!
BMW E30 - 2.5i - Must be nice and in a dark colour, coupe or touring. With the M-tec II body kit.
BMW E36 - 2.8I - Must be a coupe and something special.
Or show me what you've got!!! I don't want a slow car, poverty spec, big passion wagon etc etc.
*Sheffield (S11)
*I am more than happy to pick you up from the station if need be.
Other Details
*Please have proof of insurance if your wanting to test drive the car, if not you can still drive it at your own risk, BUT.. I want to see you have means to pay because if you crash the car, it's yours.
*I do want you to test drive the car and it's recommended so you know how well it drives.
*No tyre kickers, test pilots or time wasters please.
*I work Monday to Friday so am available any evening, at weekends and Friday afternoon.
*I'm 100% confident the first person with genuine interest to see the car will buy it
*Please PM me with any questions, if you want a phone number please just ask!
Edited by MrP
  • Replies 33
  • Views 1.3k
Found the VAG-COM File.. Dated 20.09.2010 so 10 days old..
VAG-COM Version: Release 409.1-US
Chassis Type: 6N - VW Polo
Scan: 01,02,03,08,15,17,19,25,35,41,45,46,55
Address 01: Engine
Controller: 036 906 033 D
Component: 1.6l/4V SIMOS3 00HS3512
Coding: 00031
Shop #: WSC 00788
WVWZZZ6NZ1Y222735 VWZ1Z0Y1169100
No fault code found.
Readiness: 0000 0100
Address 03: ABS Brakes
Controller: 6X0 907 379 C
Component: ABS/EDS 30 IE CAN V004
Coding: 15603
Shop #: WSC 00788
Address 08: Auto HVAC
Controller: 3B1 907 044 C
Component: CLIMATRONIC C 1.0.0
Coding: 04001
Shop #: WSC 00788
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 6N0 920 904 K
Component: KOMBIINSTRUMENT BOO V09
Coding: 00444
Shop #: WSC 00001
Address 19: CAN Gateway
Controller: 6N0 909 901
Component: Gateway K<->CAN
Coding: 00022
Shop #: WSC 00788
Address 25: Immobilizer
Controller: 6X0 953 257
Component: IMMO 0008
Coding: 00001
Shop #: WSC 00000
Address 45: Inter. Monitor
Controller: 6N0 951 171 C
Component: Innenraumueberw. 0003
Address 46: Central Conv.
Controller: 6N0 959 799 B
Component: 8U Zentral-SG Komf. 0001
Coding: 04096
Shop #: WSC 00219
Address 55: Xenon Range
Controller: 6N0 941 273
Component: Leuchtweiteregelung 0001
Coding: 00002
Shop #: WSC 00788
End --------------------------------------------------------------------------------------------------
Edited by MrP
TTT
Come on peeps, Buy this... I've seen a beautiful MK2 GTi I want....
Mr. Bump
Bargain of a GTi for the spec!
Thanks dude! I love you x
Sorry mate,
Not my cup of tea.. I really want a MK2 GTi and I'm holding out for one this time...
Good luck though!
I will also do a deal with my head unit..
It's a Alpine CDA-105ri (Click here for the spec/cheapest price)
It's like brand new (comes with box/instructions, cage and all wires) and compliments the colour scheme/dash perfectly.. Plays from an Ipod/USB stick too!... Ideally I'd want £100 extra for this.. Which is half the price of a new unit.
Edited by MrP
Nobody likes me, everybody hates me, I think I'll go eat worrrrrrrrms!
Buuuuuyyyyy Meeeeeeee!!
i know how you feel mate
Tell me about it... Makes me sad nobody wants my car... :crybaby:
This is a cool car owned by the most anal car enthusiast you could imagine. Nothing is ever good enough for this man and this car has wanted for nothing and has been improved throughout his ownership.
I made the mistake of letting him vacuum the car outside my house one time. I managed to drop and refill the coolant and completely clean my car in the same time he was doing such a hardcore job of it :lol:
If you want a good car come see this one :-)
Thanks honey bunch x
looks a real nice motor, finally found a genuinely honest description of a car, i know exactly what you mean about people describing things as mint or good then you see them and theres things they didnt think to tell you about!
I'm looking at getting a gti but not til next year :( hopefully il find one like this.
bump for a nicee car!
Thanks dude.. It might still be for sale next year at this rate :retard:
Free bump for this!
My old car and I've just reaslied how much i miss it, trust me everyone first to see will buy, beautiful motor!
Good luck :)
Free bump for this!
Good luck :)
You can always buy it back??? :-D
Right,
If this car hasn't sold by the end of October I'm keeping it... Coilovers with a healthy drop, some American spec racing wheels and some carbon fibre...
Haha I would if I handnt already bought another polo gti lol!
bump!
Buy meeeee!
Seriously!! Why has this not sold!!!??
