9N Rear Badge Removal
Hi guys..
want to paint my rear badge black, but unsure how its attached to the bootlid, will it simply come off like the badges with a bit of heat?
Thanks in advance
  • Views 996
Anyone??
Anyone??
You will need to glue it back on.
Rest a flat headed screw driver on a cloth and prize it off
How is it attached to the bootlid then? Its definitely not adhesive!
Stuck on with same stuff as the other rear badges as above gentle lever it off with a srew driver but use a clothe under it to protect the paint work
