Rear Door Wont open ?
Hi There, can anyone please give some advice on my Daughters Mk5 polo 5 door 1.2 on a 52 plate ? The central locking works on 3 of the doors and boot lid except the REAR Driver's side door. This is permently shut and I can not open it at all ! The lock is stuck shut, and i'v tried opening the door from inside -pulling door lever etc, but someone mentioned that I heve to remove the door card from inside whilst in closed position, and ruin the panel ?
I think the solenoid has failed and needs to be replaced, but surely you must be able to release this door without having to replace the interior panel :angry: ? Please can anyone advise ? And where is best to buy a door solenoid and new rear panel if required ?
Many Thanks
  • Views 1.9k
This happened on my mums 5 door not too long ago....
You will have to take the inside door card off..
But you will also have to remove the closest seat and rear bench to gain access to the door card.
The full removal can be done without any damage at all. Generally speaking what will have probably happened is the door will have leaked at some point, causing water damage on the solenoid making it firmly stick..
When this happened to my mums I couldn't pull the door pin up or do anything..
I am more than happy to describe to process to you if your planning on doing this yourself?
Edited by MrP
  • 11 months later...
Hi there,
I am in the same situation as the original poster. I have removed the window winder and the door pull cover and bolts but getting the door card odd without damaging it with the doors closed seems just about impossible.
I would be grateful for any advice or top tips before I take a crow bar to it in frustration!
