headlining
anyone here who reads FASTCAR .. will have seen the uber lush 6n on this months cover .. well it kind inspired me a lot ;)
I'm purely asking if anyone on here knows how to remove the headlining in a 6n .. mines dirty and grubby, so I'm thinking of retrimming it myself :)
piece of piss.....
you need to remove all the pillars A/B & C aswell as the piece going across at the back
remove the sunvisors, grab handles & sunroof handle & interior light
then just pry it from behind the door rubbers and remove it out of the boot so as to not crease it
30 min job max
the A pillars are just clips and need a bit of force
the B pillars you need to remove the seat belts (17mm i think) and the just pull as its clipped on
the C pillars are the same as the Bs
the piece at the top at the back is just clipped in
the sunvisors are crosshead screws or torx screws
grab handles are crosshead screws
the interior light is just clipped in
the sunroof handle is a torx screw in the handle and then just clipped in (slide forward and down)
Done =D
Hello mate. What glue would i have to use as i don't want it to soak through the fabric ?
i used fast tak....basically you want a spray on glue....mine was from wilkos
I would make sure its Heat Resistant glue as well - you dont want it falling/sagging in the Great British Summer Lol :-)
Harry
Edited by haz911
