Harnesses
Hi,
Got some bucket seats for my polo and I've been thinking of getting some harnesses to go with them. I've been looking on places like demon tweeks and they sell two kinds, bolt in and clip in.
Which kind do i buy and how do they fit in, can i use the existing seat belt mounting point or do i have to buy the eye bolts and drill any holes?
Thanks for any help.
Alex
  • Views 827
I would personally get bolt in ones. You need plates welding to the car then holes drilled and tapped into them to secure the eye-bolts too. There is a certain way to mount harnesses as well, they can kill or paralyze you if fitted incorrectly. Google fitting guides, plenty of them about, and show the best places to mount them.
Mk2?
Mk5?
I had bolt ins in my Mk3 before, rear straps bolted into the rear seatbelt clip holes.
Side straps bolted to the bottom seatbelt mount and the other side I took off the seatbelt clip off the seat and bolted it to that.
But that would only work for 4 point harnesses!
Not sure how safe it was, only had them in for 4 days :)
I used to have a group A Opel Manta stage rally car and the four point harnesses used eye bolts in the original seatbelt mounting points for the lapstraps and for the shoulder straps they went into eye bolts for the original rear belt mounting points, and it passed RAC scrutineering at every event and MOT's it was'nt even mentioned!
