Not happy with stance
Hey guys, ignoring the camber issue in the pic, i need to find a way to go lower at the front. It's not as if my car is high anyway but i would like a bit of tuck at the front as when you look at it from the side the back of the car looks lower than the front. I am all the way down on coilies at the front so struggling to find ways to get it down by just a few cm more.
Any input appreciated.
Thanks.
  • Replies 14
  • Views 1.2k
Helper springs out, failing that, I've heard lopping a coil off bring the front down a bit
should have bought some diecent coilovers?
Get some lowering top mounts and sort out that front camber you can also remove the helpers and chop the bump stops in half
hmmm can you use lowering top mounts with coilovers? defo loose the helper springs as well
Thanks for the input, but how would i go about removing the helper springs? And where can i locate the bump stops?
Yeah you can\'t use lowering caps with coilovers.
As said helpers out will give you another 20ish mm
You need to remove the coilover and take it apart and remove the short spring and fit all back together again, bumpstops are under the black rubber boot and will need chopping in half
Bottom spring on this pic
Edited by mugly
Thanks mugly :thumbsup:
Will look into this.
Bigger wheel?
the yellow n black thing in the 2nd pic is the bumpstop btw dude ;)
Cheers llewellyn, that looks a bit extreme chopping the coil :lol:
Still trying to think where the bumpstop is though, is it actually on the suspension strut?
On the rod under the black boot if you have it
Ah ok, i'll have a look later, so it would be the yellow bit you chop in half horizontally?
Correct sir
