Mixing glitter with paint
So i'm part way through refurbing some alloys, (prepped and primered)
I've decided that i want to add a bit of glitter to the wheels, but have heard and thought of several ways of doing this,
Just wnat to know which option is best,
1) Mix the glitter flakes into the colour itself?
2) Mix it into thinners and spray a layar over the top before the laquer (I dont think that will work as it will run)
3) Mix it into the first couple of layars of laquer then do a couple more layars of laquer.
Any help will be massively helpful,
x
  • Views 777
Ask panda with the 20vt 6n. he seems to do this alot so would know :)
add to the first coat of lacquer then follow with coats of clear lacquer, have heard of people putting the flake
in their hand and using an air blower to dust it over the first coat of wet lacquer but never used that method myself
as it could end up with a lot in one area :)
Ok, thanks guys, think that was the method i was gonna use
