Genesis Subwoofer & Diamond Audio Components
Diamond Audio S600S HEX (with Silk Dome Tweeters)
features:
* 6-1/2" 2-Way Component System
* Power Handling:
o Peak: 340 watts
o RMS: 170 watts
* Hexacone technology: Kevlar/Nomex/Honeycomb sandwich
* Butyl rubber surround
* 1" Silk dome tweeter
* Proprietary die-cast alloy chassis
* Flat progressive spider
* 4 ohms impedance
* Top-mount depth: 2-1/8"
£150
Genesis 12" Subwoofer Audiophile 30.01
features:
* 4 ohm single voice coil
* 250 Watt RMS
* 500 Watt Max
* Mechanical Q: QMS 8.31
* Electrical Q: Qes 0.56
* Total Q factor: QTS 0.53
* Resonant freq: Fs 24.8Hz
* moving mass: mms 111.3g
* sensitivity: dB 90.4
* mounting hole diameter: 279mm
* mounting depth: 120mm
£80
Item is used but in very good working condition and sounds great
Collection from Leicester or possibly post
Edited by rajloyal
  • Replies 9
  • Views 557
bump
bump
first dibs on the Diamonds! Payday on Thursday will see if i can afford them or not!
to be honest 1st come 1st served!
cheers
to the top
Edited by rajloyal
bump
speakers sold
subwoofer still here
bump
up
