Polo 9n3
Does anyone know if it possible to fit a RCD 510 into a polo 9n3? the RCD 200 is a bit out of date try to keep the car OME as possible
  • Views 815
Popular Days
there both double din i believe so it should be ok, when changing from the 210 to the 200 you get an error msg due to issues with the k-line ECU system but the double din radios dont use it apparently.
