de wiper blanking
de wipered the rear of my 6n i now want to sort the plate out i can smooth the plate but then how do i secure it to the car ??
can someone tell me also how do i remove the actually wiper mech the only bit left attached is some pipe what is it and how do i remove it from the car ??
  • Views 1.2k
Take the plastic trim off inside the boot
To remove rear wiper:
I presume you already have the arm & nuts off on outside.
Take off boot trim inside.
1 small screw in handle, and then the whole thing pops off.
2 or 3 10mm headed bolts holding wiper mech in, take them out after unplugging wire+washer pipe.
blank off or tie up your washer pipe or something to avoid leaking into boot.
u can attach plate with trim tape/silocone etc.
dont use superglue as it will just vibrate off/fall off when you shut boot
what is the best thing to use to blank the washer pipe with ???
Edited by pascoe92
mines just folded over atm and has cable ties round it. need to remove it properly when i have chance.
but doesnt leak or anything
how do you remove the properly as i have all day tomorrow to do it ??
dno aint looked at it yet haha
lol ill have a look tomorrow and inform you and you do like wise just incase either of us get stuck
