Paint sprayer speciallist needed
Right, I've got a 6n2 polo and am currently in the process of smoothing the bumper myself. (they already had a few cracks and stone chips from the previous owner so I thought I may aswell do it all at once.
I already have access to a good compressor and devilbliss spray gun so thats not an issue I just am not sure whether to attempt it myself or not.
I was thinking at worst I could prime them myself and smooth down with 500 grit wet and dry so it reduces the costs of getting them fully sprayed. I ideally want the whole car resprayed as some cheerfull chap keyed the whole side before I got the car and there are a few imperfections I'd like to get rid of. There were also a few dents which I've pretty much got rid of using a DIY ding puller.
Do you think spraying it myself is too much of a task, or does anyone do spray work themselfes that would be able to do it?
Any advice appreciated :)
  • Views 1.3k
from painting a few pannels (not a pro) but i have used celulosse paint and found that its crap it fades quick and you dont get a good finnish. i would say if your going to paint anything you want to look good then use 2pack but you cant bye it anymore cause its bad for the inviroment however most paint supplys will sell it you if you have a propper face mask.
Ok cheers for the advice mate, problem is its metallic, think i could possibly get away with spraying the bumpers but if i had to do the side it would mean blending the paint in and I wouldn't know where to start on that lol
most pro sprayers wont guarantee their work if you have done the prep work, so if you plan to prime it you might aswell paint it too imo.
paintwise from what i know you are left with 3 options.
1 celly - easy to use, fairly safe to use in a diy situation. has a tendancy to react if very high surface preparation levels aren't maintained. you wont get a good finish straight from the gun (you need to colour-sand, then polish) the type of thinners used will affect the finish too. for best results use the highest quality celly thinners you can afford (the good ones flash off quicker, giving a better surface finish. its the paint i would use, but then my car would have been painted in celly from factory due to it being old.
2. 1k acrylic is basically the stuff you get in rattle cans. you can spray it using a gun though. it dries satin, so requires a 1k laquer to give it some shine. I've used it in the past on a mk4 polo and it worked fine. the only downside to 1k, is that it doesn't dry as hard as 2k, which is what most modern cars (mid 90s onwards) are painted in. far safer to use than 2k though
3. 2k Unless you have an air-fed mask and preferably a garage with some sort of air filtering system forget it. the hardener in the paint contains iso-cyanates which are extremely hazardous to health see link:
http://www.hse.gov.uk/pubns/indg388.pdf
Also 2k paints really need to be baked. IMO its only really suitable for use by people who know what they are doing.
few other usefull links
http://www.austinsevenfriends.com/paint.htm
http://www.dtconcours.co.uk/paint-types.htm
have a go i sprayed my own car with 1k for the first time and then color sanded and polised it up :D
and also this for a mate that was metalic and then laquer
Thanks for the tips guys, both really helpful. when you say colour sanding what exactly is that, the rear bumper is nearly ready for priming after smoothing it and the primer is on the way :)
Jamie that is looking nice, hope I can get as good a finish too
Is it best to go light when spraying and if so how many coats do you reckon I'll need before lacquer etc?
hiya mate thanks it took a while but it getting there :D...basicly once you have painted it it will have orange peel where the paint looks like the surface of an orange lol so you sand it with 1000grit-upwards wet and dry to get it flat(being very carefull )and then use a machien polisher and compound to bring the paint back up.......depends on the paint i used MAK5 1k paint basicly a modern celly...i used about 5 coats i think and the car isnt lacqured its a single stage paint so you put more on..with metalics spray it on fine like 2-3 coats ...and then just put loads of laqure ontop and wetsand and polish the laqure and not the paint. :D
hope that helps mate
Edited by jamiet2
I'll try it out thanks again for the advice mate :)
