vw polo mk5 6n2 (2000)
I am trying to fit some fk angel eyes to my vw polo. But i am struggling to remover my standard headlights. How do i go about taking them out and do i haveto take the front bumper of at all ?
  • Views 2.7k
Yeah you will need to remove the bumper as there are three torx screw holding the lights on, one can be seen under the bonnet the other two are behind the bumper.
Hope this helps.
Pete
Hope this helps.
Pete
How do i go about taking the bumper of mate ?
Where abouts you located.
cumbria
Ah, bit far for me to come and help.
Well...
- Remove all torx screws in the wheel arches up to the bumper join, including the one going up through the bumper.
- Remove four torx screws under the bonnet near the release catch.
- Remove the indercators and there is one more trox screws behind each.
- Remove one more torx screw behind each fog light grill/non fog light grill.
- The bumper should then slide foward and down enough for you to fit you lights without fully removing.
This is how I fitted mine.
When you drop the bumper down use a blanket or something to stop it scratching on the floor, also use something to prop the bumper so stop in moving.
Hope it help.
Pete.
Got the lights sorted now mate . cheers for your pointers .
Upload some pics when you can, would like to see.
