various Gti Parts
All parts below were removed from AVY and ARC engines
AVY gti ECU - £ 80
ARC gti ECU - £80
inlet manifold - £50
Throttle body - £ 50
fuel rail, pressure regulator and loom for injectors - £ 30
AVY Cylinder head, needing valve stem oil seals replaced - £ 200
ARC Cylinder head needing new exhaust valves - £ 100
ARC bottom end, Can be used with an AFH head - £ 100
There are other various bits and pieces lying around, just ask
  • Views 379
contact: willsalter1000
He'll take the bottom end off you dude.
thanks :D
i do also have an AVY bottom end but the sump is smashed
