Polo 2002 Water leak / Sunroof
Hi,
I'm new!!! HI!!
I was wondering if anyone can help.
I have a 2002 Polo 1.9 TDI which has a sunroof. I'm not sure if its a common problem but I have a leak! Went into the car the other day and I have a inch of water in the footwell!
I understand there are 4 draints 2 at the rear and 2 at the front. I have unblocked the front drain(drivers side i think by unblocking it with a guitar string. The only thing now is when i pour water into the sunroof its gushing out by the pedals onto the footwell.
Where is the water supposed to come out from???
Is there supposed to be the nipples coming out where the door is? Is so I have looked and I cant see any so pics would be good!!!
Thanks in advance and HI!!!
Edited by Yeti
Hi,
I'm new!!! HI!!
can anyone help?
I've moved the topic and put a bit more detail on the title, hopefully it'll generate a bit more input.
Your car's a bit new for me, but do you think you could have dislodged a drain hose?
thank you Yeti.
If anyone can give me more details that would be great!
