GT cam and rear dust shields
Few things I'm struggling to get hold of;
1 piston, preferably 1.6, but I'll try another (its the retaining clip I want) - Recieved
MK2 gearbox passenger side output flange (to convert 6n box to mk2) - Hopefully sorted
Early 'loon rear bumper (has a shorter return than later models - sorted, courtesy of fisher
Edited by prankstar2003
  • Replies 16
  • Views 2.4k
mate if its the same as the mk1 i just got a set of gt drive shafts and they bolted straight but to my AEA's box and the mk1 hubs...
That may work, if the GT had a wider flange. I'm going to get some GT parts later, I may tap him up for a drive shaft too. Cheers for the help
no stress mate - I know that the standard mk1shafts wouldnt fit... I have the mk1 shafts knockin around so let me know if you need them measuring up... Safe Ad
Anyone?!?!?!?
B-U-M-P
Crankshaft sprocket recieved (thanks seanvw), still looking for the rest!
Recieved crank sprocket from genesisgt today, still after the rest!
Bump for a piston!
I've got a piston from a 1.4 8v if thats any good?? Still in the block but head gasket blew so I'm makin it into a coffee table :)
PM me if you're interested
Edited by dansharpy
Cheers to dansharpy for sorting me out with the circlips, top man
Now looking for O/S drive shaft from a late MK3. These were shorter than the earlier ones, as the moves toward the thicker output flange.
Let me know if you have one, we could compare lengths! Oh-Er! :lol:
I've got one of those late driveshafts in the garage I believe if you still need one.
New bits added as per title. Need dust shields for an mk2 up front, and some rear ones for disc brakes. Am thinking 6n rear discs should be fine due to the stub axle bolt arrangement
Hook me up sweet
Thanks to fisher for sorting mr out with the rear loon bumpers. Nice one.
After a gt cam no please, as well as those dust shields!
Bumpo!
Bumpo!
Going to bump this!
Drive shafts wanted too! Need a set with the shorter driver side - apparently fitted to the later mk2fs. Failing that, I need the driverside output flange from the older style 085 boxes. The later boxes had wider driver side flanges, hence the shorter drive shafts. But the earlier models had a wider flange, but shorter driver side D/S.
If you can help, PM me. Much appreciated
