9n drum brakes still rubbing despite new pads and drums
As above, changed shoes, drums and readjusted handbrake as per haynes instructions yet theres still a slight rub on braking.
Often worse for first 5 minutes of driving then eases slightly.
Any ideas? Pretty sure its the rears as changing the drums today has quietened it up a bit, whereas if it was the fronts it shouldnt have changed.
Handbrake cable seems looser on passenger side than drivers but this shouldnt affect pedal braking should it?
Thanks in advance for any advice.
Is the self adjustment working correctly? Also, was everything bar the friction surfaces nice and greasey?
