Best place to buy paint?
Hey guys
I've been through pages and pages on here trying to find a post about where is cheap (but good) place online to buy paint. I'm after celly or waterbased for a spray gun.
I've been to hellfrauds and they want about £40 a litre and I'm sure last time i checked, it wasn't that expensive!
Thanks for any help
Mike
  • Replies 12
  • Views 1.2k
can you not just go to your local motor factors store? they can mix it right there and then for you
not very good getting off net, colour match might be way out, best going to paint/bodyshop suppliers local
I'd personally go to a bodyshop supplies place. Theres more come-back if they mix the wrong shade for you, and you can ensure you get a good match in the first place if you can pop over to them with something like a filler flap or offcut of a scrap panel in the original colour.
I'd also recommend water-based if you must go water-based. It doesn't fade anywhere near as bad as celly, and is less prone to reacting with previous paint applications. It's not as hard-wearing as 2k though. Bird poop left on a car painted in water-based paint can burn through within a week (if left).
Also, going to a bodyshop supplies place would allow you to get hold of 2k, as you can obtain it on the grounds its a) for retail and not trade useage, and b) being used in the restoration of a vehicle that was finished originally in 2k.
Cheers guys
I'm doing a 90% repspray so a 100% isn't overly important.
How much should I be looking to pay per litre of waterbased and 2k?
price will depend on what brand the paint is, also if buying alot you may get some discount, you'll need thinners, clear and hardener aswell
Is that for 2k or waterbased?
Can thinners be used on waterbased? And what ratio can you use?
Paints4u!
Seriously, Its wicked.
there was a thread last week that would be worth you reading mike.
I'm all over it like a fat kid on a cookie!
Cheers guys
Last time I bought some water-based it was Royal Blue Metallic. 1 litre cost around £32. I can't remember the brand, but iirc I think it was Standox.
Just buying some Mars Red solid in 2k, and for the 2 litres I need of that, its costing me around £75 so approximately £37 per litre. The Mars red is produced by Lechler.
Had no bother with either brand or finish. In terms of ease of use, the water-based is virtually ready to go without the need for thinners or hardener, but without a means to aid its drying time, can take ages to dry, particularly this time of year. I also managed to get away with applying it with a £5 spray gun that came in a 4 piece kit from Machine Mart.
When using 2k though, I'd definitely recommend a decent spray gun. I just about got away with it when painting Charlie's rasta van, but the paint needed a fair bit of flatting after application as the nozzle wasn't really up to it and left me with a 'furry' finish.
To answer some other questions.
You can use rthinners with water-based, but by nature its naturally thin. As I said I recall applying it with little if any thinners when spraying an engine bay.
As for ratio. I can only remember the ratio for 2k I used when painting the van. It helps if you have a proper paint mixing tub which you can grab from a bodyshop supplies place too. The ratio I used was 4 parts thinners to 1 part paint with 15% hardener. If you look at the side of a mixing tub, you'll see how you get your ratios, plus the percentage of hardeners.
for 2k solid ratio is usually 3 parts paint, 1 part hardener and around 10-15% thinners
for metallic (clear over base), base coat is roughly 50-50 mix of base to thinners, then for the clear its roughly the same as 2k solid, 3 parts clear, 1 part hardener and around 10-15% thinner
http://www.clubpolo.co.uk/forum/index.php?showtopic=216019
oops
