rusty boot
ok yesterday i decided to start taking all the badges and the lock of the boot of my mk3 polo coupe so i could start smoothing it out but guess what.... there was shit loads of rust hidden behind my number plate and under the plastic strip above number plate. I'm not sure whether to try and treat the rust or just get myself new boot.
My car is metalic grey so if anyone has a boot in that colour with no rust then drop me a pm or if you have got any pointers on the best ways to get rid or rust then that would be great
cheers
miles
  • Views 1k
best option is new boot, once rust has started no matter what you do it will always come back
Common thing unfortunately, from where careless dealers drilled into the metal of the tailgate, rather than using the black plastic inserts in the tailgate to attach the rear plate.
As has been said, once rust has set in, its pretty much going to stay there, even if you grind it all back and put some rust treatment on it it might well resurface after 5 years or so.
you can chop out the rot and plate the affected areas, give them a skim of filler and paint, or seek another tailgate as you've suggested, though there may well be a chance you come across another one in as bad a state behind the number plate.
Yeah, it's easy enough to weld in a new bit behind the plate (even if you're bad at welding, it'll never show :)), but the bit behind the lock plinth is a bit more complex, so your best bet could well be to get a new, more solid, hatch.
i think I'm just going to try and get a new boot, the rust has distroyed all the screw holes around where the lock is and along the lip.
does anyone have one for sale on here?
Post an ad in the wanted section bud, it'll get noticed better :thumbsup:
