replace glass
basically I thought to myself I would try and remove the rear glass from my coupe (mk2) and ten minutes later I had succeeded :-D but there was glass everywhere as it had shattered :cry:
So I don't wanna smash the rest of them.. I'm fair sure I can get the quarter lights out and obviously the door windows but has anyone got any tips for getting the other rear window, windscreen and tailgate window out? Also I had a thought that maybe I could replace the broken one (and maybe the corresponding on the other side) with poloycarb as I have access to loads of it.. would this be a a good/bad idea?
cheers
Edited by robwizard
  • Views 1.2k
The secret is to start on a straight section of the window, and not in the corners. If you can get something like a pair of tyre levers for fixing cycle tyres, you can use them to gently lift the rubber seal over the bodywork without damaging the glass or bodywork. The advantage to the tyre levers is they are largely made from plastic which wont scratch or damage anything like say a screwdriver will.
Other than that, take your time and apply a little pressure and you should have the windows out without a problem.
As for poly carb, depends on how you use your car. If its used as a daily, parked up in all places and has the majority of the trim and interior still present, I wouldnt bother for the little weight loss you'll have in total. That is unless you're planning on further removing weight from the car at a later date.
tyre levers! of course.. cheers!
I was mainly thinking that they would be free and would make it perhaps slightly more difficult to smash them/break into my car rather than weight loss..
but if it would be much of a chore and not such a good idea I will just pick some up from here, usually cheap or free anyway
cheeeeers
also.. I'm in the middle of taking the tailgate off and so far I can only undo the washer pipe, can't figure out how to undo the wiring? and autodata is useless.. any help with this one? :)
You have to undo all the plugs on the inside of the tailgate, number plate lights, wiper etc. Tie a small piece of string on each plug, long enough to reach through the tailgate, then pull the cables through. Then disconnect the string so it sits through the sides of the tailgate. Refitting is simply a case of tie string on plugs, pull plugs through tailgate and connect plugs. Have done two that way with no probs :wink:
its for the mk2 so is the procedure the same? I had read that pulling the wires through was the way to go but the connectors from the heater matrix/wiper mech dont seem to fit through any of the holes :(
I gave up trying to get the plugs through the hole in the tailgate. I opted for cutting the connectors off down inside the nearside rear quarter so I could then remove the tailgate. When it comes to refitting I'm going to solder and heatshrink the loom back together. With the plugs cut off I could atleast get the loom through the hole in the top of the C-pillar.
  • 9 months later...
Sorry to bring this up from the depths but it saves me making a new topic.
Is the front window bonded in? Or is it just a rubber seal?
Cheers :thumbsup:
