g60/16v archs
i was just flicking though one of my pvw mags and saw a mk2 golf g60 and just thought 'how rude would a mk3 coupe look with them'
does anyone no if they would fit or what modifications would need to be done to them to make them fit.
I've been trying to find out there dimentions but cant seem to find them anywhere.
  • Replies 16
  • Views 1.5k
no idea but if no one posts an answer by tomorrow i could offer myspare set of golf trims up to my mk3 and get a couple of photo's for you?
Here you go.. mainly pictures but some info there..
http://www.clubpolo.co.uk/forum/index.php?showtopic=116100
mcLOVIN - could you please get a picture of your arches matched up to a mk3 because in the link above i think they have been trimmed down quite a lot.
mark_crox - thanks for the link man.. i recon they could look pretty good if you only fitted the arches rather than the whole kit and maybe colour code them.. might need a bit of fiber glass to fill in the gaps between the bumpers and arches tho.
thanx again
Edited by mk3miles
it'll actually be a mk2 there offered up to as i have to drop that off there, but it should still give you the same idea. daylight permitting as well as it's getting dark pretty early atm
ye thats cool man theres no rush.
I tried skinny bumper 16v ones before and its not even close, loads of triming.
Have a look at jack1's old saloon - that had mk1 (iirc) arches welded in and looked shit hot 8-)
I got as far as buying a set of G60 arches which are currently in my loft. Getting them to fit properly isn't going to be a job for the faint hearted, the golf's arches are significantly bigger than the polo ones so getting these to actually fit is going to require cutting and re-welding of the rear arches and significant cutting of the front arches (although it's just a single skin wing so not hard). I was planning on doing it this year (along with some other jobs) but breaking my arm badly in January put stop to that. Now planned for this winter.
do you mean cutting and welding the plastic archs or the metal arches on the car?
my idea was to cut the plastic g60 arches down the middle then cut away all the excess plastic and then stick then back together again... pretty basic but effective i recon?
As those archs are just gathering dust would you be intrested in selling them?
cutting and welding the metal, the golf arches are just bigger, you'd see the metal of the smaller polo body through the arch and itd look silly. Not selling them as I still intend to get them put on at some point.
i have fully welded golf arches on to my mk2 breadvan front and rear. I just need to finish all the smoothing at the rear and a little at the front it was a really hard job on mine as the breadvan rear arches are square so all the inner arch needs fully adapting for the new larger round golf arch. Its not perfect but i love it and il see about getting pictures up next week and maybe a build thread started once i have got my new wheels on and my new phone delivered for taking pics. Gutted i have just lost all the pics of the work done so far step by step as it was on the phone i just completely smashed not fun.
mk3miles do you know how expensive g60 arches are?!
yeah mk1 golf ones are an easier fit as they are a smaller diameter arch more like the polo. I think I paid £65 for my g60 arches but I see them go for way over £100 some times.
ye i no how much they are, i phoned my local vw garage the other day and asked them to quote me a price but they only have the front left arches in stock as they stopped making them at the start of this year but for that arch they wanted £73.29. saying that they do still make the 16v arches which are slightly more narrow and are a whole £6 cheaper lol
hayesey- i will have a look and see what there saying but i really had my heart set on the g60's.
stinkypete- can you give me some more detail on welding completly different arches onto a car, will any decent body shop be able to do it?
I welded all my arches myself and because it was a breadvan the arches sit slightly further back than they should but it looks ok. the hardest bit was making the square inner arch fit the new large round arch profile it took alot of grinding and welding and working out and alot of bodywork smoothing afterwards which isnt fully finished yet. but in my opinion it was worth it as it was what i wanted and i have gone for the no bumper look and smoothed all of the back and the boot will be getting smoothed and poppered soon to make it much better. If you were going to put them on to a coupe it would be a much easier job as the inner arches are already round and I'm sure you would just have to bend them a little further up.
Mine passed its mot with flying colours and i left all the welding uncovered so no body filler or paint so the guy could check. he said it was some of the best he has seen for that sort of thing as alot of people and garages bodge it now a days.
If you were to get it done at a garage thought i doubt it would be cheap as it is a lot of work to be fair and it depends on the state of the arches in the first place as i had to redo all of the inner sill wall around the petrol tank as it was completely rusted and there was about a 4 inch by 3 inch hole right next to the bottom rear seatbelt mount so i took out all the rust and welded in new steel sheets and also moved this inner wall further back from the petrol filler neck as to create less of a dirt trap which has worked amazingly so far.
hope this helps some more.
id go for metal ones personally-is it really worth spending a fortune on g60 plastics just to cut them up? I know someone that just got outbid on a set at 230 quid! Lol
