6n interior and dash lights
I'm spraying some of my dash white parts of centre console and other parts so i thought having blue lights would set it off, are they easy to do ie do i just swap the bulbs over ?
any help appreciated
thanks
Karl
  • Replies 11
  • Views 5.1k
need to swap out the LED's, so its a solder job.
er :lol:
gone off the idea? lol, I've got all the switches you need for sale in red lighting if that's any good to you?
sort of but the lights behind my heaters dont work anyway so they need replacing :doubt:
thats an easy one :) pop the front panel off and have a look, there's a bulb, switches are all LEDs though
I've got a load of blue LEDs and resistors that I bought years ago...is it a pain to do the job?
can i cut the wire and use block connectors :-D
I doubt it! Get a soldering iron!
Most of the botton mounted ones will probably be Surface Mounted Diodes (SMD's), or regular LEDs, either way, it'll be a case of soldering them.
Panda: My brother may well have been interested in the red switches, just got a 6n, but the wifey has just written the car off before he got it!
Bright white LED's 8-)
Also did the clocks as well in white with golf mk4 red needles.
Was a pain in the ass to do it.
*Old photo's due to doing it about last feb time*
Edited by Po*Low*
  • 7 months later...
Very cool, how did you do the one in the switches? I did the one on the guages but could not figure out the ones in the switches.
Apologies for the thread highjack. :paranoid:
Edited by danielmi
