Spray roof and weald aerial or just spray roof
Just wondering how much it would cost to get rid of the aerial and weald over it and then spray it black, and how much it would cost to spraythe roof black.
Can anyone recomend somewhere i can get this done in the Harrow, NW London area.
  • Replies 13
  • Views 1.6k
only way you will get accurate quotes is by going to bodyshops and asking yourself, prices vary alot all over the country
Edited by tahittiblue
i was just after some rough figures really, but yeah your right mate.
to save on costs you could remove the ariel yourself and fill over it with body filler and a bit of mesh.
thats what would do,easy peasy job and total cost is about £5 for the filler and sandpaper.job done in 30 mins to a hour.
as far as the respray roof you would be looking around £100 or again you could do it yourself if you have a steady hand for about £10 with cans,but you may not get the finish your after.
just a thought anyway. :-)
Sorry To high jack this thread.
I had the same problem. I removed the aerials and the hole was way bigger than i thought. I'm pretty new to car modding and fixing so as a temp fix i stuck in some quick metal putty stuff to keep the rain out as it was summer it wasn't a big deal i would like to do a proper job tho. Do you just lay the mesh in the hole the filler over it or stick it up for the inside? I was also thinking of getting it weilded as i've stripped out the lining.
cheers.
noooooo don't filler over some mesh, that is a bodge, it needs a plate welding into hole and fillered over to smooth
roof are roughly £150 to paint
to weald the aerial plate do i have to have remove the roof lining from inside the car?
its spelt weld mate
yes, remove it because there would be a chance of it catching fire
its a bodge if you dont know what your doing lol,I've performed this technique many times,not just on ariel's and the results have been spot on,I've never had any issues with it.
ofcourse you can weld over the section but for a small hole in the roof i think its abit extreme,i would agree that welding is the better choice for bigger areas such as a smooth boot,but each to there own i guess. :thumbsup:
its a bodge full stop, why do you think in bodyshops they weld everything? because its the only correct way to do it, if just filling was a way to do it then bodyshops would cut there time and do that but they don't
i have all my body and paint qualifications and if i ever did that with just filler my bosses, old tutors from college or colleagues would slap me
i would agree with you if my bodywork had fell apart,cracked etc but its stood the test of time with me.yes i agree welding is the ''best'' way but a small hole is very easy to repair/smooth over with the right technique.
i would never just bodge anywork on my car or any car for that matter,its a pikey way to do things but body filler and mesh serves its purpose for the job in hand.i guess its all down to the way its done,if you rush the job and bodge it then i see where your coming from.
please dont think I'm underestimating what your saying because i am not,I'm merely stating its a alternative way to work with long standing and professional results if its done right.
regards. :-)
get it done properly, it will just bite you in the arse at some point
ok :lol:
Mesh and filler is defo a bodge, its what most chavs use to do gash things to there cars.
Mesh and fiberglass maybe, depending on what kinda job you are doing.
I had a 'small' hole to fill for my rear wiper when i removed that. Did it properly and welded it up with a skim if filler to get it nice n smooth, then a shyt load of hammerite on the inside to stop the bare metal rusting. Just had to take it easy as your welding really close to the glass. do a incy bit then go to the other side of the hole and do a bit, then back and continue that until its all done. Doesnt get too hot then. Which is something id advise doing on the roof as its a large thin sheet, it will warp easily, if you mess it up you will just cry, fact :lol:
