boot smothing and popper questions-polo 6N
right, I've read through the guide on how to do this and it seems pretty straight forward, i can get my mate to weld me a plate in so thats fine. my question is with the popper...
i have a toad alarm in my car atm, not sure how old but it has 1 green and 1 black button on, the green unlocks the car and from what i can tell the black then green makes it lock without beeping (i dont know why u would want that) but admitidly i havnt the slightest clue what the black button is MENT to be for as i brought the car with it on.
would i be able to set it to open when i double press the black button, if not then single press?
edit: looks to be this one (a101)
http://www.londoncaralarmco.co.uk/images/A101RK.JPG
edit 2: from the looks of the user manual it can be used to pop the boot some how, not sure how though as i dont realy understand a lot of it. also i havnt a clue what the pin is, nor do i have any idea where the override button is lol
http://homepage.ntlworld.com/geoffrey.stor...s-a101-a201.pdf
edit 3: ok, its not an a101, i finly found where the box is and the override button...it says A100 plus on it, hopefuly it shouldnt be too hard to get to the right wire for the boot
Edited by m60_maniac
  • Views 998
Try a Google search for the alarm model, you could well find a copy of the installation/user manual, at least you'll know what it's supposed to do.
lol actualy i didnt think of that, it might even be on the keyfob *runs upstairs* :)
ill have a gander now
think i may have the answer to my question with this....
Bluelblack cable (Boot release output)
Output signal pulls low (to ground) - connect to the coil of the driver relay for the boot release solenoid. For safety reasons this function can only be activated with the ignition off. Once activated, the boot and internal volume sensors are disabled until 20 seconds after the boot is closed.
Note the siren will emit a small chirp every six seconds when the boot is open, to remind the user
that the boot is open
and from different site
Boot release output (on holding down the radio key button two for three seconds a negative output of 500mA will be provided. If the alarm system is in an armed state the ultrasonic sensors and the boot trigger circuit will also be disabled, and will not be re-enabled until 20 seconds after closing the boot on the vehicle)
not, just need to look into different solonoids :)
