cars not starting
just got home after being brokedown not good at all ,good knows what the problem is it sparks and petrols getting through ,I'm hating it no car :(
Edited by 01mlacey
  • Views 993
Shame your not closer i would of taken a look for you.
If thats a plea for help on fixing the problem then you wont find an answer....
More details on whats up with it!
mate i have no idea what the problem is I'm no mechanic haha my grandad is but he cant look proply till monday which is a bummer ,but ill have a look tommorow when i finish work so ill post up as much as i can to try diagnose the problem
right plugs and leads are like new.
the fuel is getting through.
I've cleaned the dizzy inside and out.
then cleaned up a load of conecters and i was suprised myself it started up :)
whilst it was started thought id leave it abit to run ,engine shakes like hell :S
then turned it off cleaned up the carb a little (did'nt take it off)
then after a few more times of starting it and leaving it running there smoke coming from somewere dint identify where from:S
and now it wont start again but after cleaning a load of connecters i cleaned them again still dont start so what do i do next
hope there some infomation there for someone to read and help ??????
