polo 6n2 heating controls lights?
should they be lit up?? since i got the car there hasn't been any lights on the heating controls.. not sure if they need to be replaced or there just isnt any?
  • Views 1.5k
should do the 6n does i know when mine went had to get the glove box out to get behind to change bulb unsure but prob the same on 6n2
they light up on my 6n2 gti in orange, same colour as window switches and wing mirror controls etc.
And theres a bulb behind the fan speed switch. Put it to position two and tug on it. You'll probably need to use a set of pliers though (but put a rag over them), so you don't scratch the switch.
The bulb just unscrews.
blue screen, red buttons
should be anyway
The same in pictures....
http://forums.tdiclub.com/showthread.php?p=719392
Bulb is a couple of pounds from Halfords.
PoloD.
sweet cheers for that! do you know the exact spec of the bulb?
On my 6n2...
Pull out the middle switch (I had to lever it out with a thin screwdriver) then pull it all the way out. There's a bulb in there. It's one of the 'general interior dash board' ones... You don't need it red or anything there's a red film bit in there.
Be careful when you take the old one out. I was impatient and smashed it and little bits of glass are everywhere.
Unfortunately mine still doesn't work, I think the fuse is gone.
