Quick question about speedo clock
Hey, just in need of a bit of info. I am finding it hard to find a replacement for my mk2 instrumental panel, as mine has a rev conter and digi clock. Is it possible to just change the speedo over as this is the only thing that is not working.i have checked the cable and its not that so it must be the clock. Any info is much appreciated.
Or if there are alternatives, like a set of clocks out of a golf , it would be great if someone could let me know.
Many thanks,
Liam
  • Views 893
anyone? is there a way of getting mk2f/mk3 ones to fit?
need to get it sorted so i can get car on road.
are you sure its not the cable? it spins while the engine is running?
The answer is yes, you can swap just the the speedos over between Mk2 clocks, of course the mileage will be wrong but just note down the old + new ones. take off the circuit board and then unbolt the speedo, really simple. 8mm bolts IIRC.
when i drive the cable will move round, this is when it is disconnected and i moved it around on my drive . so its not the cable.
ill find a speedo as close as poss and swap them over. Its a lot easier this way as the 1l non rev counter speedos are every where.
cheers
Liam
