haynes manual
hi,
i know there is a haynes manual on the site some where for 6n polo but i just cant find it does anyone have it book marked and can someone send me the link.
cheers, nick
  • Views 1.4k
hi,
cheers, nick
Halfrauds..
that doesn't really answer what he asked does it...
I dont think there is one buddy (well i haven't found one anyway!) I have got one though so if you want a specific section copied ill take some pics and send it over to you. I did an engine change recently (on my own!) and the haynes manual was an absolute godsend! If you think you're gunna need it alot then you can get them off ebay for about a fiver i think. Like i said , if you're desperate for a specific section give me a shout though.
Cheers, Dan
putting a new clutch in the 1.6 6n and need to know torque setting for pressure plate and drive shaft bolts?
cheers, nick
Had a quick look for you there mate.
Pressure plate-to-flywheel bolts, petrol engine models, 20Nm/15 lbf ft
Driveshaft bolt ( 3 stages)
1, 200Nm, 148 lbf ft
2, Slacken the nut by one turn then, tighten 50Nm/ 37 lbf ft
3, Angle tighten a further 30 degrees.
The m8 bolts must be tightened 40Nm/ 30 lbf ft
I don't think there's one online but it's well worth the money buying one, especially if you get a good bargain on ebay.
cheers for that. thanks, fou ypur help everyone
