Spraying boot vw badge
I was wondering is there any chance that i can spray the vw badge on the boot black, how do i remove it and spray it or do i have to do it with the badge on the boot?
  • Views 1k
the badge sits in a recess in the boot lid in like a rubber cup holder,heat it up with a hair dryer for a few mins to soften adhesive and carefully pry it free with a flat screw driver,easy enough to get off.
to paint it,rub the badge over lightly with some 1000 grade sandpaper,then give it a couple of coats of plastic primer,then a couple of coats of the final colour and a couple of coats of lacquer if desired,allowing 5-10 mins between each coat.
finally,when its dry,re stick the badge back on the boot with something strong such as a blob of tiger seal,or similar and hey presto!
you can do it while its on the car but its more hassle masking everything off than it is to just take the badge off.
hope this helps.
hope this helps.
Cheers mate great help, ill be taking it off as doing it while its on the boot is a bit of a bodge.
