remove rear seats in a 6n
How easy is it to remove the rear bench out of a 6n? Any guides or tips :)
  • Views 1.6k
lower bench or rear?
Lower bench less than 30seconds, just fold forward and push the rods together and pull out.
The rear section, fold down push back the clip/lock nearest the window, then remove the clip in the centre of the 60/40 split. should take you 5 mins :)
Cheers mate much appreciated. Just an experiment to see if weight reduction has a decent effect on performance :)
Nothing serious.
Just the rear seat won't really make a difference to performance. I ran my 6n basically totally stripped apart from dash and front seats and it made only a slight difference.
Back seats took me ages to figure out, you need to pull the back of the seat forward and look at the side, there will be a slidy thing you need to push back with a big flathead screwdriver. Pretty self explanatory from there on.
