Boot Lock Polo MK2
Hello, just bought a VW Polo mk2 as a project. the key fits into the boot lock but doesn't turn (obviously the wrong key) and I don't really want to have another key to open the boot so the idea of just changing the lock wont be happening. So then I was thinking of maybe buying universal central locking for it.. would this do the job? if not then I also thought if it could be possible to maybe have it the same as how the bonnet opens with another leaver at the front. Would this be possible?
I have taken the boot panel off and had a look at how it all works. I have thought of many ways to keep the boot open but not been able to lock it for example trying to turn the lock upside down so the arm behind the lock is as when it is unlocked, or welding a bit of metal on the arm so it pushes the trigger to open even when locked but none of this is so safe to have the back unlocked at all times..
Any help & ideas would be great!
Thanks Adam.
  • Views 3k
Before doing anything spray some penetrating oil into the lock. I've seen my lock seizing up and appear not to work with the original key.
Failing that I have seen me change the whole set of locks on my car from another scrapped car to get a matching set.
Ok, i will oil it up tomorrow and see. Yeah there was that too, can't believe I forgot about changing the whole set haha. I will see if i can find some, but I live in Sweden and this car isn't so popular at all
if you take the lock out and free it up with oil , after that if the still doesnt operate it you can swap the tumblers around to match the key
or a cheaper way is to fit the key the in the lock with it on the bench , and any tumblers that stick out gently file them off , it will then be matched to that key
Ok, well today I oiled it up and it worked to unlock the boot, I then tried to lock it back up and it was stuck again.. So now it is stuck unlocked. Thanks steveo3002 for the help, I think I will take it out tomorrow and have a look
ah if they key worked it ...strip the lock out and soak it overnight in something like wd40
they can be taken apart for cleaning /oiling ...but do it somewhere clean like over a sheet of paper as theres some small parts in it
Ok, thanks for the help. I will do that tomorrow or Monday :)
