Sick of this car!
It's just thing after thing with this bloomin' machine! Had to have a huge service a month or so back with 2 new brake pads and 2 new front tires, then 3 days later my clutch went, then a few days ago a headlight bulb, then I noticed a nail in my tire, just been and had it repaired and when he put the wheel back on noticed my wheel bearing is fucked! Is it like this with all cars? Or have I got a dodgy one?
Been quoted £85 plus VAT for a new bearing, so around £100? Is this a lot? Want it done cheap as possible.
There's no noise coming from the bearing, we just noticed that the wheel wobbled when the car was jacked up and all the nuts were torqued tight. How long will it last?
Any recommendations as to where to get it done in Colchester?
Cheers,
Fisher..
  • Replies 14
  • Views 1.5k
if you go to the dealer get there quote for any work then every other garage out there is cheap in comparison as for problems these things happen just keep thinking once its done its done unless its a tyre then accidents do happen unfortunatley
These sorta things happen, I've had a few weeks a couple of times where everything has gone wrong. And even with it just being a light bulb which has gone, I've gone mad...
Stick it out, just think, once these little niggles are fixed, there not going to go for another 20k :)
Wheel bearings are easy, do it yourself dude.
£15 for pair from GSF and a hour or two of your time, plus you'll get that feeling of accomplishment after.
:thumbsup:
Cheers, would love to do this stuff myself, but I don't have any experience, and probably don't have the tools for it.
Any guides anywhere on this? Haven't really got the money to get it done and would love the experience, just think i'll balls it up and have to spend more money getting it fixed.
What tools would i need for the job?
Cheers guys.
i got quoted £100 straight up for 2 rear wheel bearings and i thought tht was steap hmmm
as for llasting mines been like it for months noise coming from both and one wobbles rather alot :/
If it's the front, then check it's not a ball joint.. jack it up and have a look, double check as a ball joint should be a lot easier/cheaper than a front wheel bearing.
front or rear wheel bearing? If it's a rear one then I'd say that's pretty expensive but it is a front one then probably not bad really.
It's a front passenger side.
What am I looking for when checking the ball joint? I don't even know what one looks like! :D
I told you i knew nothing about mechanics! :p
I'm supposed to be driving London Saturday night, and the mother is saying not to, is it safe to drive with for a while? Surely if it's not even making a noise yet its not that serious is it?
Cheers.
if yours is a mk3 the rears are a tapered bearing anyway. just tweak it like a quater of a turn and it should tighten up, if not then it really is fubar'd :-)
If it is ball joint, you'll need to replace bottom control arms and I advise doing both sides in one go. About £30 for pair from GSF - Easy, only a few bolts here and there.
My advice is buy a Haynes manual my friend.
Some more info on your car would have been useful, to save us stabbing in the dark, but..
I'm assuming it's a 6N2?
If it is I'm assuming the lower wishbone is like a mk1 golf with a removable bolt-on ball joint, unlike the polo1-2f. Basically if you have the car jacked up look at the point where the driveshaft goes through the hub.. then look how the hub attaches to the lower "wishbone", there will be a pinch bolt of some sort. Whilst wobbling the hub look and see if there is movement between the hub and the wishbone. If not then it is a wheel bearing.
i drove my old mk2 breadvan with the wheel basically wobbling an inch either way it was as knackered as it gets but i had to get to work still.
when i eventually changed it i took the hub of and the bearing fell out in small pieces the only problem i had was getting the outer shell out but that was easy done with a bit of creativity.
its not a hard job it just takes a bit of patience, could try putting a request in for a local polo member to come round to help in exchange for beer?
Yeah sorry, it's a 6n2 ( does say in my details ;) ) I think I am gonna try do it myself, with someone slightly mechanical minded.
I have put a similar thread on east coast dubs, where most of the people live around my area, so hopefully someone will be kind enough to offer their assistance :)
It only has about 10mm of play at the very most, so I don't think I'm in great danger by driving it.
Thanks for all the help :)
Yeah everythin does happen at.once on mine its.been coil pack, clutch, gearbox, front track rod end, cambelt needs doing got all the.stuff and now my front bearings going gnna cost me around the 15 quid mark so in fairness jus get the the lil things dne and it will be all good
think yourself lucky its just one i need to do 1 rear and 2 fronts haha
