where to earth in a 6n2?
i know i always post stupid questions,
but can someone please take a clear picture of where they have earthed their amp in a 6n2? the place I've put it.. I'm worried its gonna blow the fuse,
thanks
  • Views 1.3k
In mine i've got a cigarette lighter plug thing on the left hand side, just underneath that there's a screw, took that out n squashed the ground behind the plastic n put the screw back in, works fine :)
mine in the boot under the spare wheel on the spike
mines on the rear seatbelt bolt, but you have to sand down the paint so it's just bare metal, otherwise you won't have a good solid earth!
And if you take the seatbelt bolt off, do not let the seatbelt retract back in, because its a sod to get back out. :p Once you take the bolt out, just pull the belt down and it should be fine! :)
i dont know which bolt you mean.. or what you mean about retracting back etc lol, can you take a picture? would be much appreciated!
Shit! :( I never even thought about that! Hahaa,yeah man, you could use that bolt, it would be much easier!
