Converting LHD/german/euro spec rear lights to AHD!
Ok got some smoked hella aftermarket rear lights off this forum and they were lhd (fog light on passenger side and reverse on drivers) as we know this arrangement is ileagle, the drivers can be remedied by a red painted/tinted bulb for the fog. But the passenger side has a red lense in it! This needs to be removed and upon further inspection the light has a seperate red lense that can be gotten to from the back! I used a weldin rod bend in a right angle at the end to hook the lense and pull it back then I used a pair of forseps to hold it through the hole above the bulb hole and then a junior hack saw blade (dremel would have been immense! As would a steady hand and soldering iron to melt it but they weren't to hand at the time!! Now I am left with both reverse and fog positions un coloured and White when a light is behind! The reverse has slighlty more diffusing bits in the lens (as it was previously a fog) but I'm sure this will be fine! As long as they all shine nicely!
Will try get some pictures but though Id get this up before I forgot!
  • Views 1k
ok so i have fitted the lights and tinted a bulb red which was far too dull but only a thin covering of paint?? so then got some led bulbs which are abit better but not perfect, could do with making them brighter if anyone has any tips on getting a bright red light??
if i remember correctly it doesnt matter what side your reverse light is on, so having it on the wrong side means nothing - to get arround the fog light issue i have a mk1 golf cabby fog lamp - job done:-) that way you dont need to piss about with your bulbs
why would it be illegal to have the fog and revers light on the opposite sides? as far as i'm aware as long as they work and shine the correct colour the side it's on doesn't matter. think about it, how many LHD car's and lorry's use our roads every year, the old bill would have a field day at the docks if this was the case :lol:
only law I know of with reverse lights is if it's present it must be working, it is not a requirement
regarding rear fog lights on the other hand! It's European law to have at the very minimum one rear fog to be present and must be on drivers side/centre line (or anywhere inbetween) also iirc the govt website side it's legal to have one on each side, they also need 10cm away from the brake lights, no closer to the ground than 25cm and no higher than (can remeber exact) about 1.5 m!!
This makes lhd cars legal! As th fog is on the left hand side!
Just thought people might wanna solution to make them pig proof! I like to make sure I'm 100% legal and above board as the popo near me will seriously do you for anything! Tried me for legal pressed plates, headlight been being to low (granted copper was sound and just "advising" me!) A cop woman even got on the ground and looked under my car for a cat!! (second day at new job, made me late wasn't impressed!)
Edited by Pepe
So the copper had a headlight beam setter in his pocket? I wouldnt take any notice of that one, (i have to keep rising the ones on our cars as there set for URBAN driving by the mot station and as we do little of that only being able to see a few feet in front of your car isnt useful)
She looked for the cat. :lol: would she have actually been able to tell the difference between the cat and middle box?
sounds like you have a real load of jobsworths round there. as for pig proof I'm afraid nothing is 100% bacon free these days.
