anyone running mini lights ?
iv just bought some and dont no what wobble bolts to buy or what to do about locking wheel nuts "/ do i need spiggot rings to make them fit all advice is welcome :)
  • Replies 20
  • Views 4k
Yes the center bore is slightly smaller on a mini than a vw, they're 56.1 not 57.1, so best bet is to get spigots. I'm not sure which ones you need but a quick search around on eBay will quickly remidy this.
To fit minilites, you will need:
Spigot rings, Bmw mini - VW fitment
Wobble bolts & (extended ones for the fronts)
9.5mm spacers for the front (Thinnest you can get, used to clear front calipers)
As the wheels are -7 ET already you don't really want to go poking them out anymore.
Hope this helps,
Regards,
Ben
type mini, minilight or minilite into the search box of this forum (i know its hard, its quite far away from the new topic button) and a plethora of threads await regarding fitting mini wheels to your polo.
simple answer is the offsets are all wrong, and youll need some archwork dependant on car, to avoid falling foul of mr plod, not to mention also having to run variance (wobble) bolts, and possibly spigot rings, dependant on centrebores.
personaly, get smoors, they are similar to minilights and are 4x100 with proper VW offsets
Hope this helps,
Regards,
Ben
yes that helps buddy thanks if i need help again ill email you :)
Hope this helps,
Regards,
Ben
bmw mini fitment is 4x100 but has a slightly smaller centre bore
real mini is 4x101.something or other and require wobble bolts and spigot rings as the centre bore is usually larger
smoors are like 130quid a corner though? theres no comparison. id rather spend 200quid for a brand new set of minilights from midland wheels and 15quid for wobbles and spigots jobs a good'un! then you would have a good few quid left to get arches rolled nicely to cover that et.
you'll need to do more than roll them, they will poke out by nearly 2".
the other option is to run minilight style wheels designed for the old mx5. they are 4x100, have vw friendly offsets and you can get them for £60 up to £500 depending on wheel spec. only downside is that they are mostly 14 or 15" which a lot of poeple dont seem to like so much.
black racing, ssr watanabe, rota and panasport are all jap brands which make them
i run ultralites, so same thing :p
44906_457393744840_517864840_5009573_545
13x6 with 145/60/13's. Spigot Rings + Wobble Bolts, no locking nuts :p
yeah but they are baby 6js, whereas most go for 7 or 8js, then wonder why they dont fit.
i had a set of 6js that i got off ebay for £40, tried them, thought they looked a bit small though
good point. id use 6s up front and 7s on back if there that bad et.
p.s jon are those mirrors off of german ebay? been looking at some that look like that on there for 24quid plus postage.
bought mine privately. the ones on ebay are most probably copies. if they are genuine englemann mirrors then they are worth a few quid.
have a pic of some watanabe rs-8s
  • 1 year later...
What size Spigot Rings did you use?
Two years later... He's in Australia for now, no chance you'll get a reply.
Least he used the search function.....
There's a search function!? :shock:
how the hell can you use spigot rings to make a wheel with a 56mm centre fit a hub with a 57mm centre??
is it me or is that impossible? :lol:
I thought the same but couldn't actually bring myself to make the effort to reply
hahah!
club polo - making physically impossible stuff possible because my mate said so. lmao
Genuinely thought the same earlier but couldn't be arsed to reply
