mk2 saloon arch catching
the guys at the garage reckon my rear spring on the fuel cap side is catching has anyone else experienced this? my spring seems to stay compressed when its down anyone?
Edited by mrbenpololoon
  • Views 1.3k
anyone?
Pic?
Pic?
cant see shit unless i removed the rear suspension which i need to do but might leave that till after winter. what have you changed suspension wise on the back wonderin if the guy i bought it of has stuck wrong springs in
Is the spring catching the wheel? Or something else? If it's catching the wheel, you may want to fit some spacers. It could be because the lower spring platform is fitted the wrong way up which means the spring isn't seating correctly at the bottom of the shock absorber.
I've got weitec 40mm springs and matching shocks on the back of my saloon as well as 15mm spacers.
Has the strut been removed and fitted the wrong way round? where the damper bolts to the axle is an integral spacer, this needs to be facing the back of the wheel, or it can cause rubbing issues. usually with the wheel though
i will have look when i get them of next cheers guys
