Removing Boot Lock
Right guys, i have a problem my boot lock is jammed the key doesn't turn iv tried spraying WD40 in the lock and left it over night also done the same with penetrating oil but it failed still jammed. So my next move was removing the key barrel, i removed the pin holding the barrel in place but it does no budge tried wedging a screwdriver to ease it off still no movement, tried putting the key in the lock and hitting it to ease it off. Heating it up to release the corrosion but failed.
I really need this sorting as at the moment i cannot unlock the boot without squeezing into the boot to unlock as my Vacuum Pump is not working so i thought i could get away with no needing it and just using the key on the boot door.
  • Views 655
Right for people who got this problem, what i had to do was remove the three screws holding the boot handle in then lift the handle up so you can get to the top of the barrel, then with a screw driver i had to make a grove into the key barrel i did have to make it quite deep then angled the screwdriver down into the grove and had to hit it hard with a hammer then it flew straight out. There was a load of muck in the barrel what was stopping the plates from moving so gave them a good cleaning and now its fully working.
Edited by ShaunPolo
