dismantling interior rear view mirror
ok guys just wondered if anyone knows how to split the mirror stalk from the actual mirror part also can i take the glass out etc? i can get it off the screen no bother but just thought id go into the task armed with some know how!
  • Views 916
The ball'n'socket (great name for a pub) come apart simply by moving the two parts around too far beyond adjustment.
Dunno about taking the glass out in one piece,good luck with that..
I suppose you could smash it out,do your thing with the casing,then get another from the breakers and cut the casing of that one to get the new glass out?
On 6Ns, and mk2 Ibizas as it happens, there is a metal ring fitted around the plastic socket to prevent the ball from pulling out, you'll need to open this up a little with some pliers, should release the socket enough to pop the ball out
Cheers fellas!
