Fitting new wing mirror- help
Hi guys just got a new wing mirror to fit on my car as the other one got smashed. How can I get the inside panel off to fit it??
Nick
  • Views 2.3k
Nick
Prise the cover off from the grab handle with a small screwdriver. There are 2 screws in the handle (cross head). Undo them. If its manual windows then there is a collar on the winder between the handle itself and the door card, slide that and the handle will come off. Unscrew the door lock pin. Then pull the door card towards you and up (its clipped in so will need a bit of force). Once the door card's off i think there is 1 or 2 screws holding the cover on where the baseplate mounting screwsd are. Unscrew them and then you will be able to see the baseplate mounting screws, undo them, unclip the connector, and the mirror should come off. Fitting is reverse of removal. Hope this helps!
Dan
Nick
Dan
Cheers mate. I got as far as removing the inside cover and I'm left looking at an inside metal panel with a layer of thin plastic covering it. I need to get behind this metal panel to fix the connector wires from the new wing mirror to the wing mirror adjuster on the inside of the car.??? Any info here would be a massive help. Never done this before.
Nick
Yeah you carefully peel that plastic back mate, it might need some sticky tape when you put it back on as the original glue looses its sticky over time
Cheers mate. So just to make sure I only have to peel the plastic back and dont have to remove the inside metal panel??
Nick
there is no metal panel, you peel that plastic back and theres holes in the door that allow you to reach anything and everything inside the door, i know its cold out but the best way is to get out there and have a look at it!! Theres nothing you can break that cant be fixed!
Cheers mate, a laod of help.! Got some pretty bad dents on the drivers side door too so might take the panel off there and try pushing them out later too. :thumbsup:
Cheers for the help
Nick
Just joined this forum as I am trying to fit my new electric wing mirror to my 1999 Polo. I have removed the panel covering the mirror screws on the inside of the door, however I cannot access the 3rd screw without - it seems - removing the inside door panel. I have pulled away the panel around the edges but it seems to be stuck firmly in the middle. These instructions, in this thread, don;t seem to make sense with my door. I have now stopped winging it and am seeking some advice! Any advice would be appreciated. :?
