i fooking passed my test!
good times,
but the sub stopped working whilst driving around, all the connections seem to be fine (ill check again in the morning)
any ideas?
my systems just gone tits up unall, massive bass then bang! fuckall!
btw, there is an 'ice' section you might have more luck getting good reply's ;)
Is there a power on light or anything? If this isnt on (or the protection light is on) then check the following:
Check all fuses, should be one inline with the power cable (should be right near the battery), one or sometimes 2 on the actual amp (NOTE:if one of the fuses is blown then dont just whack a new one in! It probably blew for a reason, check all the wiring along the entire length to make sure its not contacting the chassis anywhere, if its not THEN put a new one in, and probably turn the gain down!!). Check earth is good. Paint should be scratched away from where it is attached to the car body. Check remote at head unit end is attached (mine came off the other day!) If all else fails take the lot out and wire the amp straight to the battery, if the power light on the amp comes on now it is definately something wrong with the wiring. If it doesnt come on, you are amps fucked!
If it is on then check RCA's (signal cables) if you've got a spare set then plug them in. Also check the speaker wire going from the amp to the sub (if these are bridging this can also cause the protection light to come on) Try plugging a different speaker in to see if you get and sound out (remember to change HP/LP filter to full if it isnt a sub and turn the gain RIGHT down!) If you get no sound from the new speaker, you are amps fucked! If you do get sound from the new speaker, you are subs fucked!
Congrats on passing your test! :thumbsup:
Edited by dansharpy
well it stopped working, then started working again, then stopped again.. so I'm hoping its just a lose connection
and its an active sub so if one bit on it's fucked.. the whole thing is fucked, it was a reconditioned one which makes me more worried
Thank you for that, I will now go check my car in the morning! Was wondering on the best way of figuring out why my amp gave up!
Congratz, Great feeling when you hear,
I'm glad to say youve passed to I'm affraid youve failed
Part from mine when I'm affraid, Youve passed, He was such a jolly chap :)
