Removing trim on door
Hello
I have got a mk2 Breadvan and would like to remove the trim along the door I have already remove one part of trim but I can’t get the glue of does anyone know how to get the glue off looks really bad ?
Thanks Aaron
:-D
  • Views 1.2k
There is no glue. Have you undone the screws around the very edge at each end?
I have only took of the front part by the wheel arch to see how it was fixed on,
want to get this glue of before i remove the others
thanks Aaron :-D
Sorry,I'm miles away..
You mean the outside :lol:
Yeah,you just pull it away at the end,then gently stand on it,working along with your foot a few inches at a time.
I removed the moulding first,then warmed the glue up a bit after (two horizontal strips of it) and carefully peeled those off then.
I took mine off using fishing wire and wd40
then bought a cheap "toffee wheel" from ebay to get rid of the glue! worked a treat and looks a lot better!
dooo it! :D
Should just pull off. Mine had practically perished and was quite dry. As said, get a toffee/fudge wheel and use that on it, then use a cutting compound and polish to bring the area up to a lovely shine
Ok yer will have to try it when I get a free 5mins
If not then I will get this toffee wheel thing lol
Thanks Aaron
:-D
