Plastic Welding......
Hi all, I've got a small crack on the corner of my 16v front bumper about 3" long and wondeing if anyone knew any places around notingham - derbu area that could do it?
cheers
  • Views 1.4k
is there evan such a thing :?
:paranoid:
Could always have a go at it yourself! Or any bodyshop should do it!
:paranoid:
Yes there is such a thing.
Yeah may aswell doubt it'll cause any harm, rang a couple of bodyshops but they don't do it =/
diy it, all you need is a gas soldering iron with a melting tip attached. melt the crack together, front and back. rub down any raised edges caused by this on the front. skim with some plastic filler (isopon do a special filler for bumpers, dont use regular filler it will crack)
scotch pad the paint within 6 inches around the area (enough to just take the shine off the paint), paint the damaged area (i find an airbrush is ideal for this sort of repair), then blend the fresh paint in with the new using some cutting compound
Cheers for the reply mate, I'm not fussed about painting the area as its on a bumper i got cheap, I'm part way through smoothing it so its all getting sprayed anyway. Turns out one of my notts dubz crew works at a bodyshop and is doing it for me. Proffessional job.....and FREE! :D
You can also buy this glue stuff that welds together plastic. But i cant remember the name. Pointless post really :retard:
haha effort anyway :)
