How to remove mk2 polo bumpers
Anyoneknow please??
  • Views 3.3k
one 13mm nut holds each bracket to the chassis, by the chassis legs front and rear. 2 brackets per bumper and they pull straight off after. will need to disconnect indis and numberplate light tho
Its two bolts mate,on each bumper. One each side in the boot,one each side in the engine bay at the end of the chassis leg.
But first,you need to undo the indicator plugs for the front bumper,white ones by the bolts. And at the back the wiring needs to be undone,its in the middle directly in between the bolts and consists of one live plug and one ground/earth screw iirc.
