polo 6n with 150k on clock ?
hi i am looking at buying a polo 6n 1.3 with 150k on clock what are your suggestion a nono or will it be fine
  • Views 836
if it works fine, then i would have any issue with it, other than it being a 6n.
if its been looked after it'll have pleant of life left in it. make sure the gearbox operates smoothly and that the clutch doesnt make a squeek sound whne depressed. also check that it doesnt burn any oil when accelerating. they are strong little engines with little to go wrong.
make sure the cam belt and water pump have been changed at 120k and i would guess with that mileage, the clutch would have been replaced. if not price this into it, as it will need doing at some point in the near future.
