Rear Washer
Firstly I am sorry if this is in the wrong section, I am not sure quite what this should come under.
I have no water getting to the rear wash wipe.
The pump is working when I pull the lever.
Water leaves the washer bottle, I can hear the water going through the pipe to the rear.
Then it just stops, no water comes out at the tailgate and no water leaves the body at any place I can see either internally or externally.
The question I have is where does the pipe go once it has left the engine bay, does it go via the roof internally or via the chassis?
Ta Joe.
  • Replies 10
  • Views 1.6k
Could be that your jet is blocked.
The jet is fine its just that no water is getting to the rear of the vehicle, its leaving the washer bottle then it gets blocked in the pipe somewhere.
I just don't know where the pipe runs.
Ta.
Joe
The pipe runs up the passenger side, down by the door. It usually breaks off in behind the boot (so you need to take the plastic cover off the back of the boot), or in behind the rear door card, so that'll need to come off. :)
It doesn't take long to do, less than 10 mins to get the door card off, and the boot cover is less than a minute, it's just two screws..
Thanks Adam,
The Vehicle is a three door.
I have had the boot door cover off and nothing is getting that far.
Is there a place where it can be viewed on a three door or is it in the headlining?
Joe.
Mine did the same mate if you look at your engine bay from the front, on the right of the washer bottle at the bottom is where the hose for the rear wash is. This might have come off as that happened with mine.
Mine was leaking behind the side trim in front of the left rear shock, there was a production joint and the pipe had fallen off, leaving a puddle of washer fluid in the spare wheel well!!
Nige,
Thanks very much.
Lifted the rear seats out and like you said the pipe had come apart from the connector, spewing water all over the place.
Seats etc now drying indoors on the radiators.
Good Job.
Joe.
Also when I was in there I noticed that there is a rear boot interior light.
Should that work and if so where is the switch that triggers it?
The one I have doen't seem to work, its got a bulb in it etc.
I haven't had time to check it yet but was just wondering because mine is an E perhaps they are not wired to work.
Joe.
Joe.
I think it should be activated by a switch in the tailgate latch assembly
Thanks I will have a look later.
Joe
