can any one do guide on roof lining please
please cn some do a gide on re dowing the roof ling thnks alex
  • Views 1k
Easy !
- Buy Material
- Buy Contact Adhesive 80 Degree's
- Remove Sun Visor And Grab Handles
- Remove ABC Post Trims
- Remove Rear Trim (In Front As You Open Boot)
- Take Rooflining Out
- Cover In Glue
- Cover Material In Glue
- Stick, Remove Air Bubbles, Mould To Shape Of Rooflining & Cut Excess
Hope This Helps
JB
not easy! on a mk3 the windscreen and rear quarter windows are removed for a start! and then you are sewing a new one
I'm Just Assuming Its On A mk4.
bit more specifics would be good, along with learning to spell and use proper language!!!!!!!!!!!!!!
there are loads of threads on doing a mk4 roof lining so use the search button
