mk2 polo electric windows
any got or fitted electric windows in a mk2 mine is 1986 but i think they had them in the later models? if i found some would thet fit?
  • Views 1.8k
i have considered putting them in mine . but not sure how much room there would be for the motor etc ! let us know how you get on if you do do it :)
Vw did them for the mk3 iirc and they are next to rocking horse poop on the scale of rare. Do come up for sale occasionally, last set was sold by genesisGT I think. Not sure about aftermarket kits though
I think there were also OEM ones for mk2s too, but they're even rarer than rocking horse shit. I'm pretty sure the mechanism in mk2 and mk3 are the same, so if you find mk3 items I'm pretty sure they'll fit.
Early mk2 Golf electric windows also fit (mk3 at least) with a little work in mounting the motor - I bang on about it here. Had them in my mk3 for a good few years with no trouble :)
Mech in mk3 and mk2 is the same, so they should fit. Think the last pair i saw was up for big money. A few years ago i tried to convert a 6n motor to work with the mk2 mech, but didnt get too far :retard: Will probably try again sometime though
I think you can modify golf ones to fit, just not sure which golf :lol:
But, its something to look into atleast.
These really are rare though for a MK3
early mk2 golf electric windows fit. but they are quite rare. i got mine from an early passat- and there from the rear doors
I think this could work. After all, both the MK3 manual winder and 6n electric winder are cable operated. I think with a bit of patience and a small amount of fabrication it could be done. Mounting the motor might require a few new holes drilling...
Note though that if you do have genuine Mk2/Mk3 electric windows - though the motors look the same as the motors from a 6n, they are not direct replacements a the motor 'axle' is different.
