Cigarette lighter and radio wont work ?
If it is due to a blown fuse how do you go about changing them..?
cheers, John :-)
EDIT: (6n)
Edited by OLOP 1L
  • Views 891
there should be a 'glove box' just above your thieghs (when you are in the driver seat obv.) just take that off and they should be clearly visible,
if your smaller glove box door is the same as mine it will tell you what numnber fuse does what.
hope that helps
I'm sure you've probably sorted this by now, but if not, i had the same thing on my 6n,
the radio and lighter are on the same fuse, it was a 10 amp, at the far far right of the fuseboard under the dash,
22 i think, should say in your manual though.
