Bodywork help
Hi all, unfortunitly i didnt get any time to strip my Polo today, been a long day lol.
How do i remove the following:
Rear bumper
Front bumper
Metal plate under the rear bumper
Front grill
and
DASHBOARD lol.
Any advice greatly appreciated :)
  • Views 824
The ones I know of:
Front Bumper - you will need to unscrew it from inside each wheel arch (and you MIGHT need to remove the grill (cant remember though))
Rear Bumper - open boot, there are some screws along there just under the bottom rubber seal and then I believe there are a couple in each wheel arch
Front Grill - mine just unclipped around it, might need a flat headed screwdriver to help ease the clips out.
Not sure about metal plate or dashboard I'm afraid :)
Anyone got any more advice on removing the above please?
Front bumper you may aswell start at the bottom, remove the arch lining screws aswell at this point and work your way up, remove the splitter (all bolts are located easy enough sunken in) Take off the lower front valence (Thats the metal part) remove the plastic grille by popping it out if you look closely there are places where there is a square of plastic missing, easy enough with a hand or flat head :), then you can get a torx screwdriver and remove the main bolts there are quite a few maybe 8 cant remember exactly :) then remove the grille and grille surround, to remove the grille surround you will need to remove the indicators and then unbolt them you can only do this with the indicators out. then there should be 2 more torx screws on the top and it should pop off :)
The rear bumper you will need to remove the arch lining screws which go onto the bumper again, there are bolts holding the lower on which are located in between the larger upper bumper and lower metal valence they are plastic and easy to get off with a spanner or deep socket and are fairly small then the top should be easily unbolted from the top and maybe the bottom, but its fairly straight forward you will need to use a little bit of force i think.
The front grill there should be 4 popped in clips push them down with a flat head screwdriver and it should just gently pull out from there juggle it carefully and you will get there.
Hope this helps :) I'm not a pro but i have had all my bumpers off before this is just what i can remember
