Mk2 Golf 1.3cl(1.8 16v conv)
*3dr alpine white 1.3cl mk2 shell with new front wings and generally good paintwork, 100%solid sills and chassis legs.(still a 1.3 on the book)
*cheap tax & ins
*Fully waxoiled 6months ago
*1.8 KR 16v with all new seals
*New headgasket
*KR Ecu and ignition loom
*Performance leads
*Fresh oil/filter & Plugs
*New water pump
*New cambelt & Aux Belt
*4-1 manifold fully Heatwrapped with custom one box system
*Rear strutbrace
*Janspeed Coilovers
*Front Eibach Antio Roll bar
*New wishbones and ARB drop links
*Goodridge Hose's all round
*GTi rear Axle & GTi Front brakes
*All metal brake pipes new
*brand new Greenstuff Pads
*Drilled and Grooved discs
*13x7 Superlites fully polished
*Conti Sport contact tyres with 5mm
*GSX-r 750 Carbs
*BoggBrothers Manifold
*BoggBrothers coolant pipe/flange
*Mk3 Alternator and Multi V-ribbed belt conversion
*Facet Fuel Pump
*FuelKing Fuel pressure Reg
*Fuel press gauge
*Battery relocated to boot
*Hella smoked rear lights
*Dash Mount Rev counter will also supply another set of dials with a rev counter if you wish to bin the dash mount.
*Solid Front engine mount
*New Rear engine mounts
*New n/s/f Track rod end
*TRS 3point Harness's
*Corrado Seats
*Momo wheel
*Quickshift
*Brand new LUK clutch
*MK3 Gti gearbox
*cheap ins and tax as a 1.3
on to the bad points, the car currently has no Tax and is sorn. the windscreen has a crack in it on the lower passenger side front a stone chip. Front valance has had a hard life and its begining to show. pops out of reverse sometimes have to hold it in. all forward gears are 100% may be to do with the quickshift I'm not to sure of the fault, and some slight cosmetic corrosion in the normal mk2 places nothing major.
Open to offers around 1700 or swaps/deal for a Beetle(old of course), feel free to make me any offer you wish though =)
Polished Cam Cover and Valve caps Not included I'm afraid.
contact anytime but text between 9am - 6pm via mobile 07837427162 dont bother with pm as i drop on here once in a while
no test pilots or tyre kickers please
Regards
Liam.
  • Replies 13
  • Views 693
alryt mate just a quick question are those superlights 4x100?
bump for a sexy vehicle!!
Hey up matey =)
they are mini fitment, currently fitted using spigot rings and wobble bolts =)
cool are they 4x108 or 4x101.6
Aup Mate I've got a polo GT Stripped out in grey done 61000 will go up as its my daily on deep dish attewe ( if thts how u spell it) still got all orignal fittings if your interested in a swap. its got 10 months mot and 5 months tax pm if interested
where you located?
Whats the mileage on this? Fancy a mk4 polo?
4x101.6 matey :)
where you located?
Wilmslow, Near Manchester
sk9 5jh
with regards to swaps I'm afraid I'm only after somthing aircooled or cash :) Many thanks anyway though
Liam.
have u ever had any problems with your wobble bolts mate. cheers
omg i want it!! :|
SOLD
None at all matey =) been giving it some hard use aswell pod ect ect and they have been shaweet, just making sure you have good spigot rings that matter =)
